Forums >> Revit Building >> Technical Support >> Crash crash crash
Fri, Sep 16, 2005 at 1:39:45 PM | Crash crash crash
SteveB
3.5 Stars: 5 Votes
My revit 8.1 crashes repeatedly. I never had a problem with 7.0 It happens mostly in 2 instances...
[1] rendering a 3d view (but doesnt always happen then). The drawing just closes - no error message, etc.
[2] & when trying to export to .dwg. This results in a fatal error message.
The file is one that was created in r7.0, has a base plan imported from an autocad drawing. To work around the problem, I cut and pasted the exploded base plan that was imported into the drawing along with a simple detail line outline of the building into a new r8.1 drawing and then exported that simpler file to autocad 2004. That worked OK. I have tried audits of the drawing and no problems are found.
Anyone have any experience with this?
Fri, Sep 16, 2005 at 7:10:08 PM | RE: Crash crash crash
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Best sent to support. I'm sure they have plenty of experience in those types of issues. Please don't hesitate to send weird behaviour like crashes to support and make sure you fill out error reports when prompted (they do read them). Remember your subsciption includes support...
Sat, Sep 17, 2005 at 6:57:14 AM | RE: Crash crash crash
SteveB
3.5 Stars: 5 Votes
how does one do that?
Sun, Sep 18, 2005 at 4:34:12 AM | RE: Crash crash crash
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Log into the Autodesk subscription centre and create a support request, or alternatively go through your resellers support...
Crash!!!!
Thu, May 5, 2011 at 4:09:10 PM
crash recovery
Thu, Apr 23, 2009 at 7:02:48 PM
Parametric Cabinets causing crash in RAC 2010
Tue, Aug 11, 2009 at 1:21:18 PM
Revit crash when dimensioning
Thu, Jul 15, 2010 at 7:38:36 AM
11
Crash for single user on workshare projects
Thu, Jun 26, 2014 at 2:56:50 PM
Page generation time: 1.5900
