27 Users Online (25 Members):
Forums >> Revit Building >> Technical Support >> ROOF AND JOIST
2 Posts No Rating |
Is their a way to pin the joist to the roof? i need my joist to follow my roof slopes but cant get it to do it... HELP!!! PLEASE!!
You will want to make a reference plane in an elevation view which mirrows the bottom of your roof plane, lock those two together, and then rotate and lock your joists to this same plane.
I should also say, if you're using multiple joists, you probably should have built them with a beam system, and it's this entire beam system which should be rotated and pinned to this new roof slope reference plane.
Roof Joist |
Thu, Jun 5, 2008 at 7:37:29 AM
Cuving Joist with Barrel Roof |
Fri, Mar 6, 2009 at 7:46:53 AM
Sloped Structural Joist |
Mon, Nov 7, 2005 at 12:14:32 PM
Dimensioning a Sloping Concrete Pan Joist Roof |
Sat, Feb 14, 2009 at 11:07:40 AM
The iLevel TJI roof joist revit file |
Fri, Jul 9, 2010 at 11:28:51 AM
