Forums >> Revit Building >> Technical Support >> tagging the surface area of a floor (revit2009)
Wed, Mar 3, 2010 at 10:49:34 AM | tagging the surface area of a floor (revit2009)
sfountain
is it possible to create a tag that shows the area of a floor? Just to clarify - I dont want to create an area plan, define any areas, or rooms..so im not looking for an actual area tag.....just a simple tag that works like a door tag, only it shows the area parameter of a floor.
Wed, Mar 3, 2010 at 11:06:59 AM | tagging the surface area of a floor (revit2009)
No ... there is no tag that will give area, volumn, length or thickness unless you input the data.   Sorry.
Wed, Mar 3, 2010 at 11:14:36 AM | tagging the surface area of a floor (revit2009)
sfountain
rats.
I did make a manual tag that works, but yeah, you gotta enter in the area in the floor properties....perhaps something for the wish list then!
 thanks
Tagging 2 rooms with the same tag/area
Wed, Nov 20, 2013 at 8:11:44 PM
column surface area
Tue, May 16, 2017 at 6:33:15 AM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Surface Pattern on Modified Floor - No Skewing for Floor Plans
Mon, Sep 12, 2016 at 7:45:11 PM
images are showing area surface patterns through them
Tue, Dec 10, 2013 at 3:40:41 PM
Page generation time: 0.4040
