Forums >> Revit Building >> Technical Support >> Wire Mesh curtain wall?
Sun, Feb 28, 2010 at 6:34:48 PM | Wire Mesh curtain wall?
PatrickReynolds
PatrickReynolds Avatar
Presently, I am trying to create a curtain wall for my project that is made of a specific type of wire mesh, Lamelle from GKD Metal Fabris:
[img]http://www.gkdmetalfabrics.com/assets/products/3_4Webview/Lamelle-(Persp)_web.jpg[/img]
I've made the curtain wall panel, but it in incredibly processor intensive, and that's only a single panel, I haven't even tried putting it to a whole curtain wall yet.  Is there a default material in revit like this, or a place I can download one?  That would help me out immensely
Thanks in advance.
Mon, Mar 1, 2010 at 7:46:09 AM | Wire Mesh curtain wall?
As you have found out, you don't want to do this as a solid with void holes....   Use a material.  If they have an image of their material, you might be able to make your own pattern.  Read some of the links below and if not there, search the forums.
Mon, Mar 1, 2010 at 9:09:09 AM | Wire Mesh curtain wall?
PatrickReynolds
I need it to have transparency and glow properties, so a simple image won't work.  How do I create a material that has holes in it?
Mon, Mar 1, 2010 at 9:15:56 AM | Wire Mesh curtain wall?
4 Stars: 205 Votes
If you have that image in JPG or PNG, then open the image in Photoshop and create a new one BUT in Alpha channel, with this you can use that "Alpha Channel" image in "Bump" parameter to create the effect you want... Try and say something...
Mon, Mar 1, 2010 at 9:38:18 AM | Wire Mesh curtain wall?
Wow ... we try to help and you disregard our answer ....
As I said ... in the post below, it suggests you look it the materials - under metals!   Look at "Chrome Satin Screen"  You can change the hole type.
Sun, Mar 18, 2012 at 11:54:23 AM | Wire Mesh curtain wall?
MIDStudent
I am trying to do that same thing but for some reason I don't seem to have "Chrome Satin Screen" in my materials list... I am using Revit Architecture 2012.  Any help would be greatly appreciated on how to go about this.
Mon, Mar 19, 2012 at 8:30:11 AM | Wire Mesh curtain wall?
There are several different ones in 12.... Keep looking
You can use a bitmap for the holes - custom - or use one of the standard patters but with the size you specify.
Fri, Oct 24, 2014 at 11:10:47 AM | Wire Mesh curtain wall?
sgray05
WWHub.
Please excuse me replying to a 2 yr old thread, however I am trying to achieve the same result as discussed in this thread. I have searched all the materials that are standard with the program and am unable to find any that provide this type of mesh effect that is reflected in the image you provided.
I am working on revit 2014 and I can't imagine that they would exculde this content. Is there any place that I can easily download this material or an easy way to custom create.
Thanks.
Fri, Oct 24, 2014 at 1:21:59 PM | Wire Mesh curtain wall?
pijpiwo
pijpiwo Avatar
5 Stars: 25 Votes
It should be there.
Wire mesh curtain wall door for wire mesh wall
Mon, Sep 17, 2012 at 2:57:36 PM
Wire Mesh Handrail
Mon, Dec 20, 2010 at 3:58:42 PM
wire mesh
Mon, Jul 14, 2008 at 2:03:31 PM
wire mesh wall
Sat, Sep 6, 2008 at 7:16:56 AM
Screen wire wall
Thu, Feb 18, 2016 at 8:49:41 AM
Page generation time: 1.3165
