Forums >> Revit Building >> Technical Support >> Voids don't work when family is loaded into a project
Sun, Feb 28, 2010 at 3:08:08 PM | Voids don't work when family is loaded into a project
ldonkle
This is driving me insane.  How can this door (attached) look fine when I open the family, but NOT work when it's loaded into a project?  When I load the door into a project, the 2 panels (void sweeps) at the bottom disappear, as well as one of the void extrusions around one of the windows..
(not looking for someone to fix the family for me... I just can't figure out what the problem could be)
Mon, Mar 1, 2010 at 3:27:01 AM | Voids don't work when family is loaded into a project
Dafpfy
3.5 Stars: 11 Votes
in the family editor you can edit the wall thickness, and if you do undo redo you can see one off the voids move incorrectly in plan view.
some allign locking should fix it,
Edited on: Mon, Mar 1, 2010 at 3:27:33 AM
Edited on: Mon, Mar 1, 2010 at 3:28:49 AM
"There is no path to peace,
peace is the path."
Mahatma Gandhi.
Mon, Mar 1, 2010 at 8:13:26 AM | Voids don't work when family is loaded into a project
ldonkle
Dafpfy you are a genius.  Thanks!
So mass voids don't cut masses?
Wed, Jun 1, 2016 at 6:45:45 PM
BEWARE - Parameters don't update.
Thu, Sep 1, 2005 at 11:36:58 PM
Can't rotate object loaded to project
Fri, May 17, 2013 at 11:21:10 AM
Voids
Thu, Jul 10, 2014 at 7:31:15 AM
A Problem with Voids
Fri, May 18, 2012 at 8:41:19 AM
Page generation time: 3.9750
