Forums >> Revit Building >> Technical Support >> pat file in revit 2010
Sat, Feb 27, 2010 at 4:27:38 PM | pat file in revit 2010
Nicolai
Hi
I am having problems with making a pat file loockind like the attach. is there anyone that can help me with it??
Sat, Feb 27, 2010 at 4:38:37 PM | pat file in revit 2010
You say you are having trouble, that would suggest you have a file started - but I doubt it.  Don't you really mean you can't find one.
If you already have this in CAD, then use it.  Combination files like this are near impossible to do by hand and the file description will be huge.  I suggest you use a simple crosshatch for your vertical and horizontal lines ... then add a transparent fill in views for the dot pattern, if you have to.
Sun, Feb 28, 2010 at 4:00:18 AM | pat file in revit 2010
Nicolai
no I mean I have started making the pat file but can’t get it to work. don’t have cad so that is not a option. I have also found some patterns on the net that is almost there. But I can’t change them so they look right. They always get messed up when I try to change the programming.
Sun, Feb 28, 2010 at 10:55:22 AM | pat file in revit 2010
OK... Why don't you post what you have and we can look at it.
Sun, Feb 28, 2010 at 8:04:51 PM | pat file in revit 2010
hugh
3.5 Stars: 4 Votes
This is a simple pattern made by adding two unbroken lines to a scaled-up and translated pattern of dots:
;%VERSION=3.0
;%UNITS=MM
*2400X960PANEL
;%TYPE=MODEL
;        Pattern written by HatchKit v2.7 Hatch Pattern Editor
;        HatchKit v2.7 Hatch Pattern Editor(c) Cadro Pty Ltd 1990-2008.
;        www.cadro.com.au/hatchkit/
;-Template=DOTS,A SERIES OF DOTS
;-Date    =1/03/2010
;-Time    =12:30:13 PM
;-HatchKitVersion=2.7.1.1995
90,0,0,0,2400
0,0,0,0,600
0,30,30,30,60,0,-60
Points sometimes don't plot well so you may prefer this:
;%VERSION=3.0
;%UNITS=MM
*2400X960PANEL2
;%TYPE=MODEL
;-Source  =C:\Documents and Settings\Hugh\Desktop\DOTS.PAT
;-Date    =1/03/2010
;-Time    =12:32:04 PM
90,0,0,0,2400
0,0,0,0,600
0,30,30,30,60,1,-59
Hugh Adamson
www.hatchkit.com.au
Hugh Adamson
www.hatchkit.com.au
Mon, Mar 1, 2010 at 2:00:08 AM | pat file in revit 2010
Nicolai
Thanks the patterns you posted works great.A1000 thanks
Import PAT File
Tue, Dec 14, 2010 at 9:42:43 AM
Need help with a PAT file
Thu, Sep 29, 2011 at 12:55:36 PM
Can't import .pat file
Wed, Oct 6, 2010 at 8:28:18 PM
Revit 2012, cannot import custom pattern from .pat file
Wed, Dec 30, 2015 at 8:31:18 PM
.pat file
Mon, Aug 26, 2013 at 2:56:05 AM
Page generation time: 1.8136
