Forums >> Revit Building >> Technical Support >> Swimming Pool
Fri, Sep 16, 2005 at 4:54:16 AM | Swimming Pool
cadjockey
Hi All, I have drawn walls for a pool however in section the earth pattern hatch continues through. How do I remove the earth pattern within the pool area when viewd in section? cadjockey
Fri, Sep 16, 2005 at 7:15:50 AM | RE: Swimming Pool
fazerneil
4 Stars: 5 Votes
Presuming it is in a toposurface ? Modify toposurface. "Split Surface". Draw line round outside face of pool walls. Finish sketch. Then delete the split you have just drawn. This becomes a void.
Sun, Sep 18, 2005 at 10:13:44 PM | RE: Swimming Pool
cadjockey
Hi fazerneil, Thanks for the direction. Worked a treat. cadjockey
Sun, Sep 18, 2005 at 11:05:10 PM | RE: Swimming Pool
cadjockey
Hi , One further thing. I created the void area and deleted the element as you describe. However, I wish to now change the profile of the area I created. I am am able to manipulate the points which I used originally via the edit function but I wold like to add further points to define this area. How is this done? I am able to insert a new point but it doesn't link with the contour line created by the original points of the void. I was hoping that I could insert new points just as you can when editing a polyline within autocad. What do I do? cadjockey
Mon, Sep 19, 2005 at 4:17:54 AM | RE: Swimming Pool
fazerneil
4 Stars: 5 Votes
Helo cadjockey Select your toposurface. Edit. Delete all points relating to your original void. Finish edit and your void will have been removed. Then back to original response. Draw your new shape and delete again.
How to make a Swimming Pool?
Wed, Sep 28, 2016 at 1:23:05 AM
Swimming Pool
Tue, Dec 8, 2009 at 4:11:28 AM
swimming pool
Wed, Sep 15, 2010 at 12:54:01 AM
Swimming Pool
Tue, Jun 28, 2016 at 9:04:19 PM
Swimming Pool
Mon, Jan 28, 2013 at 7:44:57 AM
Page generation time: 0.0135
