Forums >> Revit Building >> Technical Support >> View Jumps or "Hiccups" when I click or hit escape.
Fri, Feb 26, 2010 at 4:52:50 PM | View Jumps or "Hiccups" when I click or hit escape.
mfgarrod
If I click or hit escape the whole view immediatlely jolts, and if I've clicked on an object, the object moves up.  Does anybody know what's going on?
Fri, Feb 26, 2010 at 5:09:43 PM | View Jumps or "Hiccups" when I click or hit escape.
mfgarrod
By the way, this is 2010.
Sat, Feb 27, 2010 at 5:26:52 AM | View Jumps or "Hiccups" when I click or hit escape.
4 Stars: 205 Votes
About the first question i don't have any problems like that, maybe graphic card issue? Update the drivers maybe it will solve the problem, about the second question, check if you have (or not) the "Press and drag"....
Wed, Jul 28, 2010 at 1:27:15 PM | View Jumps or "Hiccups" when I click or hit escape.
pepsiqueen
pepsiqueen Avatar
i just started having the same problem. as far as i remember nothing has changed graphics card wise, but i can't do anything in revit because every time i click on an element, it moves or flips orientation. mfgarrod, did you ever resolve the issue?
I'd rather be riding at whistler. or highland. thats good too.
edit assembly escape key
Thu, Apr 21, 2005 at 11:14:29 AM
Plan Render-No "View Size"?
Tue, Jan 13, 2009 at 4:25:21 PM
Room Styles/Room Names
Wed, Feb 3, 2010 at 1:53:30 PM
{3D} view set to "Shading with Edges" looks like "Wireframe" with color...
Wed, Aug 12, 2009 at 7:05:45 AM
11
Problems plotting "shading with edges"..................
Mon, Mar 24, 2008 at 8:01:09 AM
Page generation time: 1.2230
