Forums >> Community >> Newbies >> Inserting Views on a sheet
Fri, Feb 26, 2010 at 1:49:02 PM | Inserting Views on a sheet
gattiem18
I was just wondering if there is a way to specify where a view goes when it first goes onto a sheet.
I want my views to be placed two inches from the top and two inches from the left. Is there an easy way to set this up so it does it automatically?
Fri, Feb 26, 2010 at 3:18:37 PM | Inserting Views on a sheet
No... there is no easy way to do this.  You can add invisible lines to your sheet that you can see when you "roll over" the sheet but you can not use these except to visually nudge your views into place using your arrow keys.  BTW - zooming in makes each nudge smaller.
Inserting a 2D Component into a new project sheet [ 1 2 ]
Fri, Jun 22, 2012 at 8:39:40 AM
20
TROUBLE INSERTING VIEWS
Thu, Jan 10, 2008 at 11:03:02 AM
Sheet Underlay
Fri, Sep 12, 2014 at 2:13:25 PM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:28 PM
Elevation Views from a separate project
Fri, Jul 10, 2015 at 8:01:44 AM
Page generation time: 0.4235
