28 Users Online (26 Members):
Forums >> Revit Structure >> Technical Support >> Slanted opening through wall
3 Posts No Rating |
I have a 20" concrete wall that runs in the north-south direction. We need to show an opening that starts at the floor level on the west face of the wall. they need it to slant north at 35 degree angle and also slant vertical up the wall at 45 degrees. I have tried void sweep. I cqan only slant in one direction Any wond have an idea of how to do this? Thanks for your help
Just use an in-place void extrusion... wall type and before you finsh the void family tell it to cut that wall.
3 Posts No Rating |
I thought void extrusions had to go straight horiz or vert? I need this opening to slant not only vertical along the walls height but also run up the length of the wall. See attachment of what the opening need to do...
Use the Void BLEND...
Here is a wall hosted void made using a blend. Input wall thickness, horizontal and vertical slope angles, duct radius, recess height width and depth. I wasn't able to automate the wall thickness which is used to calculate the offset of the back opening. I hope it does what you need. I haven't included hidden lines for plan and elevation. Work calls. Matt http://www.vtourinteractive.com/
Wall opening family in slanted wall |
Thu, Sep 6, 2012 at 2:50:57 PM
How can I create opening in Slanted Curtain wall |
Sun, Oct 21, 2012 at 11:29:41 PM
opening in slanted curved wall |
Mon, Sep 29, 2008 at 10:32:57 AM
Curtain Wall in a Slanted Wall? |
Wed, Aug 8, 2012 at 9:17:56 AM
Slanted curtain wall help! (pic attached) |
Wed, Oct 22, 2014 at 6:02:39 PM
