Forums >> Revit Building >> Technical Support >> Wall Joins
Fri, Feb 26, 2010 at 11:48:26 AM | Wall Joins
mbkarp
Version: Revit Architecture 2010
I have two walls meeting at a 90 degree angle.  They are the same wall type and the corners meet at the corner.  No matter what I do the walls do not join and have a dividing line showing.  If I use the join walls command nothing happens.  If I pull the end controls on the walls the only thing that I can change is if the line seperating the walls moves from horizontal to vertical.  The walls do have a profile to them but even when I reset that they don't join.
 The very strange point is when I look at the same walls on another floor they are joined properly.  I have attached jpgs of both the first floor (problem) and the second floor (joined right).  I don't know if this is a graphics problem because I also see the second floors lineweights are not showing like the first floor (Something I also don't know how to fix).
 Thanks for any help you can give.
Fri, Feb 26, 2010 at 11:59:28 AM | Wall Joins
TKennedy
4 Stars: 8 Votes
Are your walls overlapping walls above or below?
Fri, Feb 26, 2010 at 12:46:03 PM | Wall Joins
Kardiff
5 Stars: 3 Votes
The one wall looks a little wider then the other to me
If I were you I would delete the problem wall, and make a new one starting from the join to it's desired location
should fix everything
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 26, 2010 at 12:46:04 PM | Wall Joins
mbkarp
The walls do not pass under each other.  They are straight up and down at this point of connection, the profile happens away from this corner.  There are foundations attached to the bottom.
 Although now, equally stumping is the fact that my bottom two floors of the building display plans differently than the top two floors.  They do this even after I apply the same template to each.
Fri, Feb 26, 2010 at 12:56:09 PM | Wall Joins
mbkarp
Deleting is not really an option.  I don't know which wall is the problem wall, they both have dozens of windows in them, foundations, attached to gabled roofs above....  It would take hours to recreate and with no garantee that it will fix anything.
Fri, Feb 26, 2010 at 12:58:02 PM | Wall Joins
Profiles seem to cause problems like this.  I usually split the wall horizontally at the junction where the walls are the same then they cleanup correctly.  I use join geometry to rejoin the split wall.
Fri, Feb 26, 2010 at 1:41:53 PM | Wall Joins
mbkarp
I give up.
 I have deleted and remade the walls quickly and it still does the same thing.  I tried splitting and everything and it still doesn't work.  If something else is interfering I don't know what that is.
Fri, Feb 26, 2010 at 3:32:43 PM | Wall Joins
If you could split these walls out into a very simple / everything else removed project file and post it, we could look at it.
Does anyone else wish that there was a toggle to make wall joins the default off
Wed, Aug 19, 2009 at 9:49:42 AM
Can you make wall joins Miter by Default?
Wed, Dec 21, 2016 at 1:52:44 PM
14
Wall joins in linked files
Mon, Aug 19, 2013 at 2:58:42 PM
I hate the Revit Automatic Wall joins
Thu, Oct 25, 2007 at 9:59:44 AM
wall joins
Thu, Oct 20, 2011 at 4:37:14 PM
Page generation time: 1.1285
