Forums >> Revit Structure >> Tips & Tricks >> Text Symbol Hot keys (ALT+......)
Fri, Feb 26, 2010 at 4:34:58 AM | Text Symbol Hot keys (ALT+......)
gprakash
Thought would be useful for those who might search for this.
I just ran through the numbers with ALT+ combinations to search for the symbols used frequently.
For other symbols if required, please discover :-) with ALT key in Revit text note/box.
Fri, Feb 26, 2010 at 6:07:28 AM | Text Symbol Hot keys (ALT+......)
Kardiff
5 Stars: 3 Votes
Actually that is very usefull, I wrote a viewsheet for a job yesterday and wrote diameter instead of alt 216, so tyvm Smile
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 26, 2010 at 6:18:07 AM | Text Symbol Hot keys (ALT+......)
Kardiff
5 Stars: 3 Votes
Only some of them work SadMust be a difference in keyboard langauge settings
Fri, Feb 26, 2010 at 8:15:11 AM | Text Symbol Hot keys (ALT+......)
Thread Post Kudo! #4
Guys... there is an easier way...  You can do this while in Revit.
Goto your windows start and select run ... type in CHARMAP  ... this program will show all the special keys available for whichever TTF you are using and you can select the item(s) - copy it to your clipboard and ctr'l V paste it into your revit text.
Fri, Feb 26, 2010 at 10:13:34 AM | Text Symbol Hot keys (ALT+......)
TKennedy
4 Stars: 8 Votes
I find the Alt codes to be faster for commonly used symbols. Charmap is a great backup though.
Sun, Jun 20, 2010 at 4:01:19 AM | WWHub
albertiglesia
albertiglesia Avatar
Quoting WWHub from 2010-02-26 08:15:11
thanks for this one, i am tired of memorizing the "alt" thing. this is very usefull to me
"Pleasure in the job puts perfection in the work"
 - Aristotle
Mon, Jun 21, 2010 at 9:57:46 AM | Text Symbol Hot keys (ALT+......)
jmorabito
In our office, we created a drafting view in our template called symbols and added 1 line of text with all the commonly used symbols (plus/minus, on center, diameter, center line, degree, etc.).  This way it gets loaded in with every job and all symbols are easily copied/pasted when needed.  We just thought this was easier than using all the ALT commands or the char. map.
Tue, Jul 6, 2010 at 11:59:49 AM | Text Symbol Hot keys (ALT+......)
NkatOmg2
NkatOmg2 Avatar
4 Stars: 1 Votes
WWHub:  I love CHARMAP, thanks for that information.
 jmorabito:  I really like this idea.  I think I will bring this idea up for a standard in the template.....and also make a printable list you can tack to your cube wall if you wanna ALT+ it.
 I use Autodesk Revit Structure 2011
 My songs: http://nkat.newgrounds.com
using contol or option keys when setting hot keys?
Tue, May 19, 2009 at 11:30:39 PM
Revit Hot Keys
Wed, Mar 22, 2006 at 10:52:16 AM
alt codes
Sat, Jul 11, 2009 at 11:26:39 AM
Symbol Text
Thu, Dec 10, 2009 at 5:39:08 PM
sloped annotation symbol text
Mon, Aug 15, 2011 at 8:04:20 PM
Page generation time: 0.1978
