Forums >> Revit Building >> Technical Support >> Saved Views
Fri, Feb 26, 2010 at 2:24:15 AM | Saved Views
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
RAC 2010
i want to save a view.. just one view- a very tiny .rvt file
that i can email of the one view..
the help says i can only save a 2D view- i want to save a 3D view..
when i click on save to library>save views- i get the thing you
see in this image.. it only has SHEETS.. but notice that drop-down
says show MODEL views- but it does not show any model views
to save.. i did save a floor plan sheet- and when i opened that
single sheet file- i was able to see the floor plan on a sheet and
hit the 3D button and it became the 3D model BUT it was strange-
it was transparent and shaded at the same time.. yes it would
render.. but what is going on here?
Fri, Feb 26, 2010 at 8:10:20 AM | Saved Views
Obviously the show model views only filter does not work correctly.
Unlike drafting views, any 3D view is the complete model so file size reduction will be only 2D elements and views.  All families used in the project will still be in the export.
Because your floor plan is just a view of your 3D model, you still have the full model.
Fri, Feb 26, 2010 at 4:56:57 PM | Saved Views
WYS1WYG
WYS1WYG Avatar
3 Stars: 11 Votes
wow- "does not work correctly".. what does that mean?
is it supposed to work correctly? did it ever work correctly?
saving views for use in another project??
Tue, Jan 23, 2007 at 3:28:05 PM
'unable to copy elements from file' error in inserting a saved view
Wed, Jul 25, 2012 at 10:16:55 AM
Saved File Size
Mon, Feb 15, 2010 at 6:17:13 AM
Drafting views as x-ref/blocks
Wed, Oct 22, 2008 at 11:32:29 PM
Save a sheet of drafting views
Wed, Mar 1, 2017 at 5:34:28 PM
Page generation time: 0.7847
