25 Users Online (23 Members):
Forums >> Revit Building >> Technical Support >> Foundation Wall (Arch 2009)
60 Posts No Rating |
I am adding foundations to my floor plan and am curious if anyone has created a foundation stem wall with a typical spread footing attached to it. I was thinking this wall should act just like adding a footing to a wall, just pick the wall and it (stem wall and footing) attach to the base of the wall we pick. Crazy...? thanks
What you are doing is correct because when you go to schedules, everything is in the right category, BUT, what you ask is possible to create like you can see in the images below, create a Profile family (can be parametric if you want), then load into the project and duplicate a foundation wall, then add a "Sweep" with that profile, adjust the values (offsets and so one) and you have what you want.....
Edited on: Sun, Feb 28, 2010 at 11:43:25 AM
Foundation Wall attaching to wrong layer |
Fri, Nov 28, 2008 at 4:42:10 AM
Split Region Wall Foundation Issues |
Wed, Jun 1, 2011 at 5:36:25 PM
foundation wall tag |
Wed, Jul 22, 2015 at 1:22:24 PM
WALL FOUNDATION CORNER |
Tue, May 5, 2015 at 10:17:12 AM
Foundation Wall Family Edit |
Mon, Apr 20, 2009 at 5:53:01 PM
