Forums >> Revit Structure >> Technical Support >> Moving Floor Levels Independently
Thu, Feb 25, 2010 at 10:31:02 AM | Moving Floor Levels Independently
ArchBrad32
I have tried moving levels in Revit Architecture 2010 and some levels will move independently and others move levels with them.  I have opened all views and made sure there aren't dimensions linking levels together.  I need to move each level to different heights individually...
Thu, Feb 25, 2010 at 12:45:54 PM | Moving Floor Levels Independently
4 Stars: 205 Votes
In a elevation/section view, you can pick and change the elevation (Z) of your levels.
Thu, Feb 25, 2010 at 1:13:38 PM | Moving Floor Levels Independently
ArchBrad32
I have tried that numerous times, and the problem is not that the levels won't move, it is that the levels move together, and I need each level to move individually.
Thu, Feb 25, 2010 at 1:24:35 PM | Moving Floor Levels Independently
Ah but your levels were linked together....
To Fix This... Add a dimension level to level then lock each one then unlock each one.  If a locked dimension is deleted, the dimensiuon is deleted but the lock remains.
Thu, Feb 25, 2010 at 1:31:01 PM | Moving Floor Levels Independently
4 Stars: 205 Votes
Are you sure you don't have locked the some levels? In your elevation view check in VG>Annotation Category>Dimensions and see if the "Dimensions" are turned ON.
Thu, Feb 25, 2010 at 1:37:17 PM | Moving Floor Levels Independently
ArchBrad32
WW hub, you ROCK!
Revit 2014 Moving Levels left and right Independently in each view
Thu, May 15, 2014 at 10:01:11 AM
Cannot see my floor levels
Tue, Mar 10, 2015 at 12:42:26 PM
How do you reassociate elements to other levels without them moving???
Sat, Sep 23, 2017 at 9:30:17 AM
11
Floor levels slightly offset
Mon, Nov 5, 2012 at 10:23:46 AM
Moving up Multiple Tower Levels
Thu, Feb 17, 2011 at 3:55:01 PM
Page generation time: 0.4099
