15 Users Online (13 Members):
Forums >> Revit Building >> Technical Support >> Window Mullion Problem
14 Posts No Rating |
In my quest to learn revit I am trying to create an existing building that I did in cad. I have a situation where I have a split window. I built both sections as curtain walls and inserted the mullions as required. (see attached) the grey area between the mullions is where I need to fill in. That area in the project has an insulated metal panel (instead of glass) inserted between the top and bottom mullions. I have though of 3 possible ways to do it. 1. Build a 3rd curtain wall in theat space and make the glass opaque. (Which I think I can figure out.) 2. Some how extend the vertical mullions from the bottom widow up to the top of the top window and somehow fill the area in. 3. Create a curtain wall the full height, fill in the mullions as required and somehow turn just the glass section I need to be an opaque section. What do you people think? And if you tell me 2 or 3 what is the easies way to do either of those? Thanks
viewable file for above.
I figured it out. Thanks if you were going to respond.
Mullion |
Sat, Oct 17, 2015 at 9:53:54 PM
Mullion Array gone Arry |
Thu, Oct 5, 2006 at 9:17:10 AM
Window Family issue - Revit 2012 |
Sun, Jun 12, 2011 at 11:12:58 AM
problem with horizontal mullion |
Mon, Oct 31, 2011 at 2:44:39 PM
Window Family Problem |
Fri, Jul 31, 2009 at 1:32:18 PM
