Forums >> Revit Structure >> Technical Support >> Blunt cuts on wide flange beams?
Wed, Feb 24, 2010 at 10:17:21 AM | Blunt cuts on wide flange beams?
davidlowery
I have some steeply sloping W18x35's at the roof and I need the ends to be vertical.  How do I do it?
Wed, Feb 24, 2010 at 10:49:51 AM | Blunt cuts on wide flange beams?
Kardiff
5 Stars: 3 Votes
Make it using Solid Blend, use the same profile at the top and base, and it'll angle how you offset your profiles and give you a vertical profile finish
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Wed, Feb 24, 2010 at 11:07:32 AM | Blunt cuts on wide flange beams?
davidlowery
Hmmm.  After messing with the Solid Blend for fifteen minutes I am confused.  Why is it such a pain to trim a beam at an angle?
Wed, Feb 24, 2010 at 11:22:35 AM | Blunt cuts on wide flange beams?
davidlowery
UPDATE: I did it using a Void Blend.  I just voided out the triangle I didn't want.  I hope this works for the Architect's model!
Wed, Feb 24, 2010 at 12:07:16 PM | Blunt cuts on wide flange beams?
brettgoodchild
brettgoodchild Avatar
4 Stars: 17 Votes
I think I would have gone with the "Opening By Face" command instead...a lot less complicated and requires less RAM allocation.
See attached image.
"You cannot escape the responsibility of tomorrow by evading it today. "
                             ~ Abraham Lincoln
Wed, Feb 24, 2010 at 12:53:37 PM | Blunt cuts on wide flange beams?
4 Stars: 205 Votes
Why don't you just use the "Cut" tool with a "Ref. Plane"?
Wed, Feb 24, 2010 at 2:09:17 PM | Blunt cuts on wide flange beams?
brettgoodchild
4 Stars: 17 Votes
That is an excellent recommendation Ty!
The only reason I do not use that method is to avoid having any more workplanes in my model, named or otherwise...
One large benefit to Ty's suggestion is that if the slope of the beam changes, the cut stays vertical
                             ~ Abraham Lincoln
Show Hidden Line - Not working the way I want it to
Mon, Nov 19, 2012 at 10:52:43 PM
Historical Wide Flange sizes
Fri, Aug 7, 2009 at 12:22:35 PM
Kicker Bracing
Tue, Apr 30, 2019 at 12:03:07 PM
Concrete Columns and Beams cuts through wall...
Mon, Feb 4, 2013 at 8:10:15 AM
3d snapping or not?
Mon, Jun 20, 2011 at 1:00:19 PM
Page generation time: 1.7041
