Forums >> Revit Building >> Technical Support >> RAC 2010 How to change the date format in a drawling list (NOT TITLEBLOCK!)
Tue, Feb 23, 2010 at 5:18:21 PM | RAC 2010 How to change the date format in a drawling list (NOT TITLEBLOCK!)
rudyard
1 Stars: 1 Votes
Hi, I have searched the forum and the same common question is asked but in relation to titleblocks which I can amend fine.
When I create a drawing list (view-->new-->drawing list) I add the parameters 'Sheet Issue Date' and the format is month/day/year.
 I need it to be day/month/year yet I cant seem to find a way to alter this parameter.
Can it be done or is this particularparameter fixed?
Tue, Feb 23, 2010 at 6:09:22 PM | RAC 2010 How to change the date format in a drawling list (NOT TITLEBLOCK!)
TomDorner
4.5 Stars: 25 Votes
The OTB Revit parameter for sheet issue date is a simple text field.  The sample text is in the dd/mm/yyyy format, but you can simply type anything you want into the field.  It will take any text entry and doesn't care about formatting.
Personally I wish Revit had a true database parameter type of "date" that we could format and do calculations on.
HTH
Tom
www.reviteer.com   http://twitter.com/Reviteer
Tue, Feb 23, 2010 at 10:24:58 PM | RAC 2010 How to change the date format in a drawling list (NOT TITLEBLOCK!)
rudyard
1 Stars: 1 Votes
Thanks for the reply, so if I change it via a text I can assume it is not paramtetric and then will not update as things reissued etc?  I will have to keep track of that the old fashioned way?
You mention OTB which I assume means out of the box, can I create my own parameter for drawing sheets and format it how I like?
Thanks again
Wed, Feb 24, 2010 at 9:22:04 AM | RAC 2010 How to change the date format in a drawling list (NOT TITLEBLOCK!)
TomDorner
4.5 Stars: 25 Votes
Yes OTB=Out of the Box
And yes you can create as many parameters as you want and apply them to view and sheets (and all other Revit categories as well)
The core or Revit is a database that is object based and it allows a great amount of customization of object properties.
See the Revit help file for "Shared Parameters" and "Parameters".
Tom
Sheet Issue Date Format
Tue, Apr 3, 2007 at 5:05:49 PM
Tue, Apr 15, 2014 at 7:21:31 AM
Format Label Date/ Time Stamp [ 1 2 ]
Thu, Oct 22, 2020 at 12:22:53 PM
21
Titleblock Date Issue
Tue, Jan 15, 2013 at 10:41:19 AM
Current date in formula on titleblock
Tue, Oct 9, 2012 at 8:09:59 AM
Page generation time: 0.5515
