12 Users Online (10 Members):
Forums >> Revit Building >> Technical Support >> Curtain Walls
18 Posts No Rating |
I would like to draw a Storefront wall w/ the glass in the middle of the wall and only 1/2" to 1/4" thick. Revit's default is 1" thick and it offsets the panel / glass from the middle of the wall. Is there a wall to change this setting? or do i have to manually change each Glass / Panel indiviually?
The panel thickness and offset from the center of the wall are properties of the curtain panel type itself. Hightlight a curtain wall panel (tabbing helps), then either change the properties you desire or duplicate and create a new type with the properties you want.
HTH
Tom
I've done that and that only changes that particular panel. If I try to put in grid lines or draw another curtain wall after that, it goes back to the original settings.
Make sure you are editing the "type" parameters of the panel.
Tom
Ok, that was the step i was leaving out. i had edited the wall and not the properties. thanks.
Angled Curtain Walls - fillets and nested |
Thu, Apr 23, 2009 at 5:42:47 PM
Curtain walls |
Mon, Nov 7, 2011 at 10:28:33 AM
Curtain Walls |
Wed, Apr 16, 2008 at 1:30:46 PM
curtain walls in legends |
Tue, Feb 23, 2010 at 9:50:09 AM
14
solid walls transparent to curtain walls and railings in back.. |
Mon, Oct 29, 2012 at 7:34:26 AM
