Forums >> Revit Building >> Technical Support >> Attaching chairs to an extruded floor?
Tue, Feb 23, 2010 at 2:25:59 PM | Attaching chairs to an extruded floor?
PatrickReynolds
PatrickReynolds Avatar
I am attempting to set up a sloped floor for an auditorium space in my project.  Presently I have had to make a different floor for each of the chair heights.  This seems incredibly inefficient.  SO instead I have now created the sloped floor (more specifically, I created a roof by extrusion, but it should theoretically work the same for my purposes)
Now the problem I am having is that I cannot find the "attach" option for the chairs so I can assign them to floor object.
I've included a screenshot, I need the floating chairs the be aligned vertically with the sloped floor beneath them.
Thanks in advance.
Tue, Feb 23, 2010 at 2:28:39 PM | Attaching chairs to an extruded floor?
PatrickReynolds
ok, so it didn't include my image in the post.  Here it is.
 [IMG]http://i41.photobucket.com/albums/e262/cstgirllover/Architecture/Revit/ChairsandFloor.jpg[/IMG]
Tue, Feb 23, 2010 at 3:04:50 PM | Attaching chairs to an extruded floor?
TomDorner
4.5 Stars: 25 Votes
Take your chair family, open it up, go to the family categories and parameters, check the "work plane" based box, save family, load into your project.
The family will now want to host itself to the faces of your floor.
Tip: Go to 3D view and place a chair on each riser.  Then switch to floor plan to position, copy/array.
Alternate: Create new face based family and next the chair family into it.  Use similar to above in project.
HTH
Tom
Tue, Feb 23, 2010 at 3:49:50 PM | Attaching chairs to an extruded floor?
PatrickReynolds
Ok, that worked.  Thank you, but now it's saying "Can't rotate element into this position" when I try to turn the cahir to face the front of the auditorium.
I guess I could edit the family to face the correct direction, but I would prefer it if there were some other method.  Any thoughts?
Tue, Feb 23, 2010 at 6:03:05 PM | Attaching chairs to an extruded floor?
TomDorner
4.5 Stars: 25 Votes
Can you use the space bar to rotate the chair prior to placement?
Tom
Barcelona chairs
Tue, Aug 14, 2018 at 3:37:04 AM
extruded generic model and mass floors (2012)
Fri, Sep 21, 2018 at 3:36:03 AM
IN NEED OF these 4 chairs to be built
Thu, Mar 10, 2011 at 11:04:53 AM
Unwanted transparency in Chairs (Revit 2013)
Tue, Nov 13, 2012 at 6:48:16 AM
I am dying to get my hands on a these Zuo Modern chairs for revit
Thu, Nov 13, 2014 at 6:03:11 PM
Page generation time: 2.5875
