Forums >> Revit Structure >> Technical Support >> grade beams
Tue, Feb 23, 2010 at 1:18:03 PM | grade beams
seniorcad143
1 Stars: 1 Votes
Does anyone know how to put in grade beams that does not have a wall above them?
Yeesh - Where is My Cad
Tue, Feb 23, 2010 at 1:24:57 PM | grade beams
seniorcad143
1 Stars: 1 Votes
ok - do I just put in a structural wall for a grade beam and just don't use a footing?
Tue, Feb 23, 2010 at 2:15:54 PM | grade beams
pdoug
3 Stars: 2 Votes
In Revit Structure you can model concrete beams...simply load the family and modify it by creating the specific types as you go.  Are you using Revit Architecture?  If so, I am not familiar with the interface as far as tool layout in the arch program - but I would guess you should be able to place concrete beams...someone else might want to jump in on that if this is the case.
Tue, Feb 23, 2010 at 2:26:14 PM | grade beams
seniorcad143
1 Stars: 1 Votes
We are using Revit Structure - we just didn't know if we should use concrete beam or structural wall.
Tue, Feb 23, 2010 at 2:40:26 PM | grade beams
pdoug
3 Stars: 2 Votes
I understand now...I would assume using beams would make more sense because you could modify them as you would like.  I have done a few jobs requiring grade beams before I started using RST, but not since!  It would be nice to know what you find out, thanks-
Pier caps in Grade beams
Mon, Aug 29, 2011 at 2:01:13 PM
concrete grade bms / pile caps
Thu, Nov 13, 2008 at 2:34:26 PM
Grade Hatch in Elevation
Wed, Aug 6, 2008 at 12:03:16 AM
Wall finishes and grade
Tue, Aug 31, 2010 at 12:33:10 AM
invisibility below grade
Fri, Jun 29, 2007 at 9:38:06 AM
12
Page generation time: 0.0644
