Forums >> General Discussion >> Revit Project Management >> AutoCad Architecture or Revit
Tue, Feb 23, 2010 at 12:39:12 AM | AutoCad Architecture or Revit
AhmedMaherNasr
Dear RevitCity' member
I am architect woring in saudi arabia i am brand new in BIM solution
there is a dialectic in my office about using ACA (AutoCad Architecture)
or Revit
i want to here from you what is advantage / disadvantage between
the two applications
thanks a lot to you and your world
Ahmed Maher
SR. Architect / ZFP
Tue, Feb 23, 2010 at 8:06:51 AM | AutoCad Architecture or Revit
I think you should visit the AutoDESK website.  There are some good whitepapers that deal with the advantages of Revit.  Comparing Revit to AutoCAD is like comparing a Racehorse to a donkey.  They are really not comparable.  Although Revit has CAD functions and is actually better at CAD for buildings than AutoCAD, Revit is not CAD.  And although AutoCAD Architecture tries to be BIM, it is not.
Think about this too....since AutoDESK is pushing Revit, I believe AutoCAD Architecture is on its way out.
Tue, Feb 23, 2010 at 8:07:56 AM | AutoCad Architecture or Revit
coreed
coreed Avatar
4 Stars: 16 Votes
There are no advantages to using Autocad Architecture over Revit. PERIOD !!
Go with Revit !!!!!!!!!
hth
best regards,
coreed,aia
bmpArchitects,Inc.
Long Live Revit
Tue, Feb 23, 2010 at 10:19:27 AM | AutoCad Architecture or Revit
TomDorner
4.5 Stars: 25 Votes
This subject has been discussed at length on this and other forums.
Bottom line do your research and choose wisely.
Personally you would never get me to go back to a CAD based solution.
Revit = Database that can do architectural graphics (80% data, 20% graphics) = Future
ACA = Graphic engine that can handle a little bit of data. (80% graphics, 20% data) = Past
Tom
Autocad Architecture join the Revit Architecture Suite
Tue, Aug 19, 2008 at 9:14:55 AM
Just received New Revit Architecture Bundle
Mon, Sep 22, 2008 at 6:26:19 PM
Walls Imported from AutoCAD Architecture 2009
Thu, Nov 11, 2010 at 11:30:08 AM
Linking 3D Dwg files from AutoCAD Architecture to Revit MEP
Thu, Aug 26, 2010 at 7:48:24 AM
migrating from autocad architecture to revit
Sun, Oct 14, 2012 at 4:36:34 PM
Page generation time: 4.4888
