Forums >> Revit Building >> Technical Support >> SPLIT SURFACE and GRADE REGION
Thu, Sep 15, 2005 at 3:31:39 PM | SPLIT SURFACE and GRADE REGION
arccodex1
3 Stars: 1 Votes
I have a rather large topo model. I need to edit a small portion of the grading. I thought it would be simpler to cut the surface into parts and GRADE REGION the parts but the SPLIT SURFACE tool leaves the edge of the surface visable. I've tried to change the LINEWEIGHT to invisible with no luck. I've also tried the GRADE REGION tool on the entire site but the program hangs. The site model is about 56 MB I also have a condition where part of a building is buried in the hillside such that the grade spills onto the roof of the building (a sod roof). I've been using a FILLED REGION to show this condition in section. Are there better methods for representing this? Post edited on 2005-09-15 15:32:12
Thu, Sep 15, 2005 at 7:54:24 PM | RE: SPLIT SURFACE and GRADE REGION
arccodex1
3 Stars: 1 Votes
I think I'll split the surface, make the changes I need, then merge the surfaces.
Split region on a wall surface Revit 2010
Thu, Feb 11, 2010 at 2:18:07 PM
join wall with split region with wall without split region
Wed, Dec 21, 2011 at 8:30:01 AM
split surface hides surface aligned component families
Wed, Jul 31, 2019 at 7:37:57 AM
Split Region Wall Foundation Issues
Wed, Jun 1, 2011 at 5:36:25 PM
Graded Region from split surfaces
Fri, Feb 1, 2013 at 8:36:27 AM
Page generation time: 0.2583
