Forums >> Community >> Newbies >> Problem with Sunset rendering in Revit2009
Mon, Feb 22, 2010 at 11:47:11 PM | Problem with Sunset rendering in Revit2009
rollie
rollie Avatar
3 Stars: 1 Votes
Hi guys..im just wondering..why is that  when i do sunset rendering using exterior sun and artificial (customized sun and shadows setting around 5:50 pm) all my lighting fixtures doesnt lit up?why is this happening always..ive tried different settings..i've checked my light is "ON" and still..theres no light at all..just the sun..pls help me..thanks alot.
Tue, Feb 23, 2010 at 5:36:15 AM | Problem with Sunset rendering in Revit2009
4 Stars: 205 Votes
I did several renders images in the past with more or less that configuration and i didn't had any problem so, must be something with the Lights... Edit the Light family and check if every is ok like the light position (the Yellow light), check if is not inside the geometry and so one, another thing, try to render but change the hour to 5:30Pm and see if the lights appear....
Tue, Feb 23, 2010 at 9:02:39 AM | Problem with Sunset rendering in Revit2009
rollie
rollie Avatar
3 Stars: 1 Votes
hi mr.typoon..thanks for ur reply..ive checked the light..and it was okay..and ive red some of ur reply from other thread..that u were suggesting that the wattage should be changed to 100, or 1000...i made mine as 2000 from all the pinlights..and yet its stil abit dark..sometimes i just hate doing sunset rendering, coz i always end up..rendering it on "artificial lights only" and adding a nice sunset background pic on photoshop..ive attached the image i rendered having the setting of Ext Sun and Artificial,5:30pm..with no adjustment on the exposure(coz the sky gets lighter wen i do that)..tnx..
Tue, Feb 23, 2010 at 9:08:12 AM | Problem with Sunset rendering in Revit2009
rollie
rollie Avatar
3 Stars: 1 Votes
i always end up on this setting-artificial lights only Cryingsee attached image) when i try render a sunset perspective with lots of studio lights inside the stucture..coz, its rily abit dark wen theres no studio light inside..
Tue, Feb 23, 2010 at 12:57:49 PM | Problem with Sunset rendering in Revit2009
4 Stars: 205 Votes
You solve the Problem? what kind of lights are you using? By the way, i like that "Mustang Shelby".....
Mon, Mar 8, 2010 at 4:52:29 PM | Problem with Sunset rendering in Revit2009
rollie
rollie Avatar
3 Stars: 1 Votes
hi..mr typhoon..i tried but still no luck..so i resorted to my ussual setup--"artificial lights only" and photoshped the background..btw im using pinlights..and added some studio lights to make it easier to brighten up the scene..and..thanks for the car..hehe..:-)
Tue, Mar 9, 2010 at 6:11:01 AM | Problem with Sunset rendering in Revit2009
HDDWG2003
HDDWG2003 Avatar
3.5 Stars: 11 Votes
Did you try some thing as high as 10,000 watts? I have had to do that in the situation you describe.
Tue, Mar 9, 2010 at 6:21:55 AM | Problem with Sunset rendering in Revit2009
rollie
rollie Avatar
3 Stars: 1 Votes
10,000 watts..?as high as that rily?no i havnt..but i will try that later and post here asap the result..thnks for that info..
sunset renderings
Fri, Dec 22, 2006 at 9:16:49 AM
Rendering Questions re Sky
Tue, Sep 19, 2006 at 4:34:00 PM
Revit 2009 Rendering Problem(Black screen) [ 1 2 ]
Mon, Apr 1, 2013 at 2:45:28 PM
27
Rendering Problem
Wed, Feb 6, 2013 at 1:41:48 PM
Problem while rendering
Tue, Feb 12, 2013 at 1:37:23 AM
Page generation time: 0.8283
