Forums >> Revit Building >> Technical Support >> Roof problems with 2 gable roofs with different pitches.
Mon, Feb 22, 2010 at 12:59:53 PM | Roof problems with 2 gable roofs with different pitches.
adeuley
I am trying to join two roofs. One has a pitch of 6/12 and the other of 14/12. I can create both of them fine but can't seem to join them. I have tried using the Join roofs command but they don't create a seam between them. I have included a picture for reference. Any help would be appreciated. Thanks.
Mon, Feb 22, 2010 at 1:15:28 PM | Roof problems with 2 gable roofs with different pitches.
jterrell
3 Stars: 5 Votes
You'll probably have to do some manual cutting using vertical openings if the roofs won't join
Mon, Feb 22, 2010 at 1:15:54 PM | Roof problems with 2 gable roofs with different pitches.
4 Stars: 205 Votes
Pick in that small roof, go to properties, change the "Rafter Cut" to "Two Cut - Square" then use the "Join/Unjoin Roof" tool....
Check the image attached.
Tue, Feb 23, 2010 at 2:35:11 PM | Roof problems with 2 gable roofs with different pitches.
adeuley
I have tried cutting opening and changing it to square plumb but I still get the error message that they can not be joined.
Wed, Feb 24, 2010 at 1:43:20 PM | Roof problems with 2 gable roofs with different pitches.
4 Stars: 205 Votes
That's the Error? so... that's the problem.....
Wed, Apr 28, 2010 at 4:28:42 PM | Roof problems with 2 gable roofs with different pitches.
egoled
Hey guys i need some help.
 I need to build a roof that looks like this photo.. is there a way to build a double pitched roof. I have tried to join to seperate roofs but with no success. I have also tried to draw the roof with a valley but did not work. I hope some one can help me as I need a solution fast.
Wed, Apr 28, 2010 at 4:30:54 PM | Roof problems with 2 gable roofs with different pitches.
egoled
Also it would be helpful if any one had ideas with how to replicate the brickwork
Wed, Apr 28, 2010 at 9:27:44 PM | Roof problems with 2 gable roofs with different pitches.
erland73
erland73 Avatar
4.5 Stars: 85 Votes
You can use Roof by Extrusion and an image for the brick work.....
Sat, May 1, 2010 at 1:27:57 PM | Roof problems with 2 gable roofs with different pitches.
egoled
erland
 Thanks realy appreciate that thanks... thanks for the quick response
How to join 2 gable roof?
Mon, Sep 28, 2009 at 9:16:37 PM
joining roofs
Mon, Jan 9, 2006 at 1:20:09 PM
Can't manipulate roof pitches?
Thu, May 7, 2009 at 2:01:25 PM
Extending one gable roof into another
Wed, Jun 11, 2008 at 3:09:42 PM
Dormers on complex roofs
Tue, Sep 20, 2011 at 11:11:37 AM
Page generation time: 0.3330
