Forums >> Revit Building >> Technical Support >> cannot rotate the reference plane of a swept blend
Sat, Feb 20, 2010 at 2:19:00 PM | cannot rotate the reference plane of a swept blend
stevek77
would like to rotate the reference plane of my swept blend. i am able to choose rotate and t he swept blend appears to rotate, but then it just stays in the same place.
any help MUCH appreciated - been at it for about 1/2 hour.
Mon, Feb 22, 2010 at 6:45:56 PM | cannot rotate the reference plane of a swept blend
stevek77
about 7 hours here and there into this with no solution so far. basically, i have a trapezoidal shape (looking from plan view) that I am attempting to sweep blend (see attached image). I am able to "In-Place Mass" this shape which is a ramped curving bridge.  However, I am not able to re-attribute the mass shape as a floor, so it is on the same layer as all my other masses and disappears when massing is turned off.
when i try to use component modeling to create this floor, i use swept blend but the reference planes are locked parallel to the path of the sweep.
I really really appreciate any advice one could give. every procedure in revit 2010 is taking forever at this point. i've given up on revit altogether, but this is the last thing i would like to do to finish this 100+ hour massing dummy model.
I'll be getting out my pens to trace over all the massing images to attempt to explain my proposal to somehow after that, otherwise i might not have hair left Smile
Tue, Feb 23, 2010 at 6:22:35 AM | cannot rotate the reference plane of a swept blend
Kardiff
5 Stars: 3 Votes
instead of rotating your sweep why not draw a reference plane along where you want it and just base it on that ?
Im guessing you want it parallel with your section ?
that would be the best way to accomplish this
either that or just move your top/base profiles so that the angle it makes is correct
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Please help me with swept blend!!
Mon, Jul 28, 2014 at 3:31:14 PM
Swept Blend
Fri, Nov 28, 2008 at 4:39:26 PM
need help with massing
Thu, Feb 13, 2014 at 7:46:28 PM
swept blend with more than 2 profiles
Sun, Nov 18, 2012 at 5:21:23 PM
Swept Blend for Basin
Tue, Oct 31, 2017 at 3:38:16 AM
Page generation time: 0.2418
