Forums >> Revit Building >> Technical Support >> Cannot choose edge of a pad in Revit 2010
Sat, Feb 20, 2010 at 11:08:11 AM | Cannot choose edge of a pad in Revit 2010
stevek77
oh my gosh.
I have been trying to insert a wall at the edge of my building pad for almost an hour now.  whatever i do, i cannot select the edge of said pad...i tried re-drawing the pad, no luck. please don't tell me revit is not capable of drawing a wall at the edge of a pad.
any advice greatly appreciated. thanks!
Sat, Feb 20, 2010 at 11:18:22 AM | Cannot choose edge of a pad in Revit 2010
4 Stars: 205 Votes
What do you mean? you can use the "Pick Line" tool when you are creating the walls...
Sat, Feb 20, 2010 at 12:40:32 PM | Cannot choose edge of a pad in Revit 2010
stevek77
pick line tool will allow me to choose model lines, col center lines, model faces, other walls, just not the edge of a pad. any pad when i am in a plan view - even on the same layer as said pad.
it doesn't make any sense to me - it seems a fundemental feature of a building pad is to be able to draw one's building on it.
is this not a feature of revit?
Sat, Feb 20, 2010 at 12:43:54 PM | Cannot choose edge of a pad in Revit 2010
stevek77
...to clarify, i am referring to using the pick line tool in a plan view, not default 3d. in default 3d i am able to use the pick line tool and it highlights the pads.
 i'd just like to figure out what i am doing wrong as it is excruciating to draw a plan in isometric views Smile
Sun, Feb 21, 2010 at 5:16:33 AM | Cannot choose edge of a pad in Revit 2010
4 Stars: 205 Votes
"pick line tool will allow me to choose model lines, col center lines, model faces, other walls, just not the edge of a pad. any pad when i am in a plan view - even on the same layer as said pad." - "...to clarify, i am referring to using the pick line tool in a plan view, not default 3d." - Sorry but Yes you can, see the video: http://screencast.com/t/YzkyNTI0
Building Pad Problem
Thu, Dec 20, 2012 at 3:51:08 PM
Sloped Building Pad
Thu, Oct 6, 2011 at 3:12:49 PM
Revit 2010 Slab Edge Trouble
Mon, Feb 15, 2010 at 8:54:39 AM
Topo slopped pad (parking lot/road)
Mon, Aug 24, 2009 at 8:26:23 AM
basic pad ?
Mon, Jul 21, 2008 at 10:38:41 AM
Page generation time: 2.9442
