Forums >> Revit Building >> Technical Support >> Roof Sheeting Overhang
Thu, Sep 15, 2005 at 5:32:30 AM | Roof Sheeting Overhang
cadjockey
Hi All, I have attached an image of a fascia that I am working on. You can see the fascia as a two piece unit. I have shown the roof structure as well by setting the visibilty to fine. How do I extend the end of the top layer only on this roof (the roof sheeting) to extend beyond the fascia line? cadjockey
Thu, Sep 15, 2005 at 10:38:47 PM | RE: Roof Sheeting Overhang
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
add the extension as a special fascia type then join it to the roof to remove the line (providing its the same material)
Thu, Sep 15, 2005 at 10:59:45 PM | RE: Roof Sheeting Overhang
cadjockey
Hi Mr Spot, I tried that. It didn't work. I'll try again. However, I did create a void sweep at the roof edge to cut it to the profile I need. How do you re-use the void sweep you created in another location? I do not want to create the same profile each time I need to cut a roof edge. cadjockey
Roof Overhang extension
Fri, Feb 3, 2017 at 8:20:07 PM
can't adjust roof overhang
Mon, Feb 16, 2009 at 12:12:59 PM
unable to add roof overhang
Tue, Mar 8, 2011 at 1:15:32 PM
Flat roof Overhang with profile
Tue, Apr 13, 2010 at 9:59:56 AM
changeable Overhang thickness
Mon, Oct 8, 2012 at 5:02:32 PM
Page generation time: 2.6229
