Forums >> Revit Building >> Technical Support >> Gradient color Fill
Fri, Feb 19, 2010 at 9:03:09 AM | Gradient color Fill
apanico
Is there any way to create a gradient color fill in a plan view.  I am wondering if you can create a colored site plan as you would normally do in Photoshop.
Fri, Feb 19, 2010 at 10:03:04 AM | Gradient color Fill
HWurtele
HWurtele Avatar
the only way i can think of requires actually rendering the site plan.  you have to give your topo surface a material with some reflectivity and then render as you would a normally would.  the sun in the model will give you a little gradient on the surface - that probably would take more time than photo shop though and i doubt this is what you are looking for.
in 3d views you can apply gradient to your sky but this is the only gradient i can think of in RAC. (search gradient in the help tab and its the first thing that pops up).
Sat, Feb 20, 2010 at 2:52:04 PM | Gradient color Fill
apanico
Gotcha - - thank you.
Rendered Color Gradient Not Aligning
Thu, Feb 9, 2012 at 4:14:11 PM
Area Plans with Color Fill Through Walls
Thu, Oct 8, 2015 at 6:50:30 AM
Hatch with gradient soid fill? or alternative ways to pattern this
Mon, Dec 17, 2007 at 12:01:22 PM
Can I have all my areas on drawing but only few values on Color fill legend?
Tue, Oct 30, 2018 at 7:32:26 AM
color scheme/fill pattern
Mon, Jul 9, 2012 at 4:56:36 AM
Page generation time: 1.0885
