Forums >> Revit Building >> Technical Support >> Can I change my default Imperial Style to Metric without re-installing?
Fri, Feb 19, 2010 at 5:50:46 AM | Can I change my default Imperial Style to Metric without re-installing?
danmate28
Hi, I have installed a student version of Revit 2010 Architecture and I must have missed the Configure part of the installation and it has defaulted to Imperial.
 Is there anyway I can change this to Metric without re-installing, I looked at templates folder but there was only Imperial?!
Thanks in advance.
Fri, Feb 19, 2010 at 6:56:31 AM | Can I change my default Imperial Style to Metric without re-installing?
A metric template should have been installed as well.
You could make your own template.  You may also find some in the old-on-line library: http://revit.autodesk.com/library/archive2009/html/index.html
Change from Metric to Imperial
Sun, Feb 17, 2013 at 9:26:03 AM
Change imperial to metric
Wed, Mar 11, 2009 at 9:20:24 AM
Default Folder
Wed, Feb 13, 2013 at 7:15:21 AM
showing metric and imperial elevations
Thu, Jun 3, 2010 at 3:34:46 PM
Change all units from imperial to metric without UN
Sun, Feb 17, 2013 at 9:16:15 AM
Page generation time: 0.5790
