Forums >> Revit Building >> Technical Support >> Importing Autocad to Revit, adding details and notes, then back out to Autocad
Thu, Feb 18, 2010 at 8:57:44 PM | Importing Autocad to Revit, adding details and notes, then back out to Autocad
shellp2
I am using Revit 2009.  I have been using Revit for several years...seasoned I would say...single person firm.  I had a fellow architectural firm ask if I could help get them through a deadline.  I've checked out what they want me to do and it should be no problem.  I know I can do the work if I can get the technology worked out.  I know Revit, I don't know Autocad.
So, they had done a roof plan and quite a few details in Autocad.  What I want to do is import several sheets of the project, the roof plan w/ title block and then several detail sheets.  I want to add text to the plan and then draw some of the details (some I can cut and paste and add information to them.)  Then when I am done, I need to be able to export the sheets to Autocad so they can add the sheets to their set and have a Autocad file.  CryingUsing Revit more like drafting in 2D.)
It seems like it should be doable, but I didn't find much in my search in the forums.  I am now dreading I made a promise that isn't doable.
Any help or direction to tutorials or even if you said that I am crazy and not to try to do it...
Autocad Text imported
Tue, Dec 4, 2007 at 9:29:14 AM
Autocad details linked into Revit
Mon, Jun 6, 2016 at 1:54:23 PM
Autocad details with hatch showing as black/solid
Wed, May 22, 2013 at 11:47:29 AM
Revit looking Like AutoCAD
Tue, Oct 4, 2011 at 4:41:28 PM
text in imported autocad drawing
Wed, Apr 9, 2008 at 2:20:58 PM
Page generation time: 3.7345
