13 Users Online (11 Members):
Forums >> Revit Building >> Technical Support >> Room Crisis
32 Posts No Rating |
Hypothetically speaking... let's say I have multiple rooms placements in an actual room - (each room placement has certain parameters filled in). is there anyway to consolidate all of their parameters into one room without manually entering them in. thanks.
If they all have the same information then just use one of them. If they don't then how would you decide which parameter to use? Obviously - Revit can not choose.
do you mean with invisible borders as if it were open plan, or a multi use room ?
- Just trying to help out while I wait in the office for my renders to complete www.danrossiter.co.uk |
no, WWHub was right. The situation arose from multiple people working on multiple files that were then linked in and the master file obviously didn't like that. I was looking for some magical too good to be true command to somehow fix a nasty room schedule. Thanks for your time, both of you.
room bounding not recognizing room separation line [ 1 2 ] |
Thu, Aug 18, 2016 at 10:02:14 AM
16
Room tag not showing in only one room. [ 1 2 ] |
Sat, Sep 27, 2025 at 3:40:00 AM
15
ROOM TAG TAGS ONLY HALF OF THE ROOM |
Wed, May 6, 2015 at 8:58:21 AM
box around room number on room tags |
Sun, Dec 13, 2020 at 9:59:00 AM
Room Problem |
Mon, Jan 23, 2012 at 9:09:06 PM
