Forums >> Revit Systems >> Technical Support >> Parameter that adjusts according to a parameter in an other family
Thu, Feb 18, 2010 at 11:51:53 AM | Parameter that adjusts according to a parameter in an other family
javva
I'm trying to make a beam move according to the hight of another beam. (Steel IPE) Is there a way to make a length-paramter pick a length from a parameter in another family?
(I've got two beams on top of each other, with a small opening between. When i change the type of the top one (i.e. from a beam with hight d=100 to another with d=140, I want the lower beam to move 40 mm down...)
Thnx!
Thu, Feb 18, 2010 at 11:58:28 AM | Parameter that adjusts according to a parameter in an other family
javva
Solved my problem in a different way, -still wondering about the initial question thoug...
Thu, Feb 18, 2010 at 1:46:14 PM | Parameter that adjusts according to a parameter in an other family
A nested family can read parameters passed by the host family but no family can read information from the model.  We would like doors to know how thick the wall is that they are placed in but they can't.
Loadable Family Parameter Problem
Mon, Jan 16, 2006 at 5:49:28 PM
Add Family name to a shared parameter
Tue, Jun 23, 2015 at 8:50:48 AM
Can a Yes/No Parameter control a Length Parameter?
Thu, Mar 22, 2012 at 12:17:27 AM
Referencing a Shared Parameter in a Family parameter formula.
Thu, Jan 29, 2015 at 1:26:24 PM
Add angle parameter to generic annotation with offset parameter
Mon, Mar 2, 2020 at 12:57:06 AM
Page generation time: 4.4244
