17 Users Online (15 Members):
Forums >> Revit Building >> Technical Support >> Create unequal seat joist?
7 Posts No Rating |
Is there a possibility to create a joist with an unequal I need a seat of 100MM thick on one side and 150mm on the other. Thanks
Yes. In the joist family, change the seat depth parameter to "Seat 1" (or whatever you want to call it), then on the other end replace the existing seat parameter with "Seat 2".
7 Posts No Rating |
I'm in the joist family editor and can't find the place to modifiy the "seat" length
It may not be parametric. If you don't see a parameter controlling it, it is likely constraned to work planes, or possibly with dimensions. If it is controlled with a locked dimension, just unlock the dimension and assign a parameter to it. If it's controlled with planes, you may be able to just dimension the work planes and assign a parameter to that dim. You'll have to be careful that there is nothing else controlled with those planes though.
Sloped joist seat |
Wed, Oct 24, 2012 at 1:26:11 PM
Joist Seat Elevation?? HELP!! |
Fri, Apr 11, 2008 at 10:35:49 AM
Joist Seats of Unequal Depths |
Thu, Jun 12, 2008 at 9:19:49 AM
Different seat depths same joist? |
Wed, Nov 11, 2009 at 6:32:10 PM
bar joist seat depths |
Mon, Nov 21, 2011 at 2:49:44 PM
