Forums >> Revit Structure >> Technical Support >> Ground beams not joing to pile caps (but usually work fine)
Thu, Feb 18, 2010 at 5:09:23 AM | Ground beams not joing to pile caps (but usually work fine)
paolo1982
im using revit 2009
and when i edit a hole in the slab, it unjoins a load of beams from my pile caps and i now cant rejoin them. all the material and levels are the same and they were fine before
does anyone know a way round this of if there is a patch i need to update revit,
Thanks
Thu, Feb 18, 2010 at 6:27:45 AM | Ground beams not joing to pile caps (but usually work fine)
Kardiff
5 Stars: 3 Votes
probably after you edited the shape it asked if you wanted to attach assiocated walls and joins and you pressed ok, meaning that everything has changed offset
select an element, press detach and hover over your floor, if it highlights it means im right and you can deatch and then attach everything back in place after
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Pile caps, Beams, and columns not visible in 3d
Sun, Jun 8, 2008 at 6:40:02 AM
Joining isolated foundations to concrete beams - 2009
Thu, May 7, 2009 at 1:43:52 AM
Isolated foundations (pile caps) on sloping surface
Wed, Nov 15, 2006 at 11:17:20 PM
concrete grade bms / pile caps
Thu, Nov 13, 2008 at 2:34:26 PM
Creating a Pile Schedule
Mon, May 23, 2011 at 10:37:27 AM
Page generation time: 2.5117
