Forums >> Revit Building >> Technical Support >> Dome with Curtain wall-Help on flat surfaces
Tue, Sep 13, 2005 at 5:42:14 PM | Dome with Curtain wall-Help on flat surfaces
MackAttack
So I am creating a dome on top of a building and my dome has some steps in it so there are some flat areas created on it. The question is how do I get the flat areas to have a curtain system on it and align the mullions with the other parts of the dome. So basically I will have a donut shape with the mullions pointing to the center of the donut. Hopefully this makes since. See attached file THanks for the help Mack
Tue, Sep 13, 2005 at 6:18:31 PM | RE: Dome with Curtain wall-Help on flat surfaces
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
No attached file?? Sounds most likely like a job for the massing tool.
Tue, Sep 13, 2005 at 6:45:20 PM | RE: Dome with Curtain wall-Help on flat surfaces
MackAttack
I am trying the attachment again. And yes I did use massing and am trying to apply components to the faces. The problem I have found is with curtian systems and/or sloped glasing is that I cant figure out how to basically do a rotated array with curtain grids. Hopefully the attachment comes this time. oops just looked and the file is too large see jpg for image
who knows how to apply a curtain system to surfaces with the same direction.
Thu, Aug 4, 2011 at 3:12:21 AM
Create a half dome
Mon, Nov 11, 2019 at 5:37:42 PM
a dome of glass ??? [ 1 2 ]
Wed, Nov 26, 2008 at 1:48:50 PM
17
Dome roof
Mon, Jan 17, 2011 at 7:52:22 AM
14
How to create surfaces in a new family
Sat, Aug 6, 2016 at 3:34:09 PM
Page generation time: 0.5153
