Forums >> Revit Systems >> Technical Support >> horizontally mounted duplex receptacles
Wed, Feb 17, 2010 at 3:29:11 PM | horizontally mounted duplex receptacles
Dthon
I'm trying to find a family distinctly the same as the standard revit duplex receptacle family, except horizontally mounted as oposed to the stndard vertical. I tried to manipulate the existing family by rotating the whole component 90 degrees, but it keeps giving me errors involving the restraints. I'm looking to show them installed in a wall mounted raceway.
It's frustrating as i don't see why we can't just edit the standard one and rotate it horizontally rename and resave. I can however rotate it in the project but then i lose the annotation symbol i need for my plan drawings.
 any suggestions?
Wed, Feb 17, 2010 at 3:30:51 PM | horizontally mounted duplex receptacles
Dthon
****also when i do edit the family and rotate it, if i delete the restraints the component loads into the project with seriously thick lines almost looks like a smudge on the drawing
Fri, Feb 19, 2010 at 1:08:52 PM | horizontally mounted duplex receptacles
anna2004
4.5 Stars: 3 Votes
If you place the out of box receptical then select it and hit space bar it will turn in spot.
Fri, Feb 19, 2010 at 1:37:46 PM | horizontally mounted duplex receptacles
anna2004
4.5 Stars: 3 Votes
Never mind I see what you mean. I worked through it though and found a solution. i have the file
Mon, Feb 22, 2010 at 8:02:04 AM | horizontally mounted duplex receptacles
Dthon
Anna thank you! i will download the file and have a peek. I wound up temporaryily solving it buy using a wider raceway and installing them vertically, but the clients request was to have them horizontal. Thanks again for your help!
electrical receptacles
Mon, Jul 21, 2014 at 12:17:05 PM
Objects not showing in "fine" detail level
Tue, Mar 3, 2009 at 9:54:59 AM
Ceiling Mounted Receptacles
Mon, Mar 19, 2012 at 12:19:14 PM
How to place receptacles per NEC
Thu, May 23, 2013 at 9:13:51 AM
How to Wire Multi-Circuit Receptacles Within 1 Conduit?
Mon, Mar 21, 2011 at 1:19:06 PM
Page generation time: 1.2485
