Forums >> Revit Structure >> Technical Support >> Batch printing sheets from multiple files
Wed, Feb 17, 2010 at 2:45:00 PM | Batch printing sheets from multiple files
reedvalve
Hey-
My first post here...
Is it possible to batch print sheets from different .rvt files a la AutoCAD batch plotting?  I have the batch print utility installed in my Revit 2010 x64.  From what I can tell, there is no advantage to the batch utility over the regular plot command - you can only print the sheets of the "current" file, despite having several open simultaneously.  Further, you can't drag and drop files into the batch dialog.  Am I missing something here?
Thanks in advance
Ethan
Anyone else have issues with slow batch printing to Adobe Acrobat?
Tue, Jan 10, 2012 at 11:13:42 AM
Batch printing - ARRRRGGGGHHHH!!!! [ 1 2 ]
Thu, Jul 19, 2012 at 7:57:40 PM
16
Large project with multiple buildings - file management
Mon, Feb 25, 2013 at 4:32:17 PM
Printing?
Fri, May 11, 2007 at 12:36:53 PM
Combine multiple sheets into a single PDF file per THE SHEET INDEX
Fri, Jul 31, 2015 at 3:00:27 PM
Page generation time: 3.2381
