19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> Opening through multiple walls
8 Posts No Rating |
Hello,
Please visit this site: http://www.autodesk.co.uk/products/autodesk-revit-family/overview
This seems to be a shared option between MEP and structure but is there any way to do this in Revit Architecture?
Arslan
Edited on: Wed, Jun 26, 2013 at 5:43:53 PM
We do not have the same tool in architecture. If the two walls are touching, join geometry will cut the door / window opening in both walls. But not if they are not touching.
8 Posts No Rating |
Thanks, I guess I was lucky in this particular case nearly all of my walls were touching. For one however, it was about 4" away from the exterior wall with the openings and the join geometry worked flawlessly, any distance beyond that and it does not seem to work.
Yes you can join walls even if they're not touching in Architecture and the inserts will cut on both walls.  I think you have a max of 6" gap between wall to join). see attached from help file.
"If you tell the truth, you don't have to remember anything" |
Wall Opening |
Mon, Jul 8, 2013 at 4:00:11 PM
Creating multiple curtain walls in normal wall |
Sun, Aug 18, 2013 at 11:06:14 AM
Picking multiple faces when creating walls |
Fri, May 6, 2011 at 2:12:40 PM
Opening Tool in JOINED Walls |
Thu, Jul 22, 2010 at 6:18:37 AM
Sweep wrap around external walls with opening |
Wed, Jun 25, 2008 at 10:55:55 AM
