Forums >> Revit Structure >> Technical Support >> Huge Regeneration time after defining a new element
Wed, Feb 17, 2010 at 6:39:46 AM | Huge Regeneration time after defining a new element
Horia
I think this problem was discused in Revit Building section. Afetr defining a beam i get a regeneration process bar that lasts for 30 seconds. This problem was not present at the begining of this new project in REVIT STRUCTURE 2010.
How can i solve it? I don't what to imagine what will happen when the structure will be totally drawn as i am still at the basement level.
Thank you and please note that i am a Revit begginer.
Wed, Feb 17, 2010 at 8:34:59 AM | Huge Regeneration time after defining a new element
Horia
I have managed to solve temporarly the regeneration lag problem. I have deleted the slabs that i had allready defined earlier. Now everything is smooth. However this is stange because it means that i have to draw all vertical elements and beams from bottom to top and only after this step to proceed at defining the slabs. Kid of stange assuming the inplane diferences between the underground levels and the ones above ground floor.
Still waiting some other opinions.
Thanks
Huge Time Lag w/ Wall or Room Edits ... Regenerating ... 1-2 minutes per click [ 1 2 ]
Mon, Jun 16, 2008 at 10:56:43 AM
15
revit 2013 very huge file, huge and slow
Tue, Jul 1, 2014 at 3:07:24 PM
MEP-Slow Piping-Huge Lag time
Tue, Jan 4, 2011 at 4:54:14 PM
Why do I get these huge trees?
Mon, Aug 24, 2009 at 10:45:16 AM
13
parameter dims huge in fmaily
Wed, Oct 22, 2014 at 4:56:28 PM
Page generation time: 2.6941
