Forums >> Revit Building >> Technical Support >> Area of the structural elements in schedule
Tue, Sep 13, 2005 at 1:34:33 PM | Area of the structural elements in schedule
Pamfi
Hi, What is the quickest way to extract the area for painting for every structural steel column and beam? I try to create a formula for this but even in the column/beam families I have access to the a,b,thickness values I cannot find a way to use them into the schedule. any help? Thank you, Florin
Tue, Sep 13, 2005 at 6:11:09 PM | RE: Area of the structural elements in schedule
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Unfortunately the surface area of beam is not something that's easily calculated. It would need to be done manually as unfortunately, as you mentioned you don't have access to the beam length to include in the formula. I suppose you could create a formula to work out the surface area per millimeter of beam... and set it up as a shared parameter. Then you could create schedule in the project adding this shared parameter and multipling it by the beam length?? This should give you what you desire but requires a fair bit of overhead. Of course once you have all you beams modified it should be quite simple. HTH.
Monitoring Non-Copied Structural Elements
Wed, Jun 25, 2014 at 10:27:34 AM
Worksets in structural projects
Mon, Jan 9, 2017 at 5:53:42 AM
Structural elements are disjoined
Tue, Feb 8, 2005 at 5:17:37 PM
Replacing Structural Elements in Arch Model with Revit Structure elements
Sun, Dec 4, 2011 at 4:06:34 AM
Area Plan does not match Area from Materia/l Area
Tue, Feb 13, 2018 at 7:50:03 AM
Page generation time: 2.5293
