Forums >> Revit Building >> Technical Support >> problems with families from revitcity
Mon, Feb 15, 2010 at 7:07:09 PM | problems with families from revitcity
sukram
Every once in a while a file I download from revit city becomes unreadable, Win 7 is not able to determin the size of the file I am not able to delete it, revit cannot open it. The only way to remove it from my pc is to boot to safe mode with command prompt do a "cacls" and take ownership then delete. Has anyone else had this type of problem? My system is Core 2 duo with 4 gigs running win 7 64bit and revit arch 64bit.
Mon, Feb 15, 2010 at 7:11:09 PM | problems with families from revitcity
I don't believe this is a problem from RC but is a system problem on your end.  I've heard of something similar to this before but I can't find the post.
Tue, Feb 16, 2010 at 6:11:03 AM | problems with families from revitcity
4 Stars: 205 Votes
Here you have: http://revitclinic.typepad.com/my_weblog/2010/02/thumbnail-previews-and-locked-files-in-windows-explorer.html
Tue, Feb 16, 2010 at 7:59:46 AM | problems with families from revitcity
erland73
erland73 Avatar
4.5 Stars: 85 Votes
I have the same problem but only when I use Firefox, so I download them with IE. Another possible solution to solve this issue is: don't save it but open it. Once you have your file opened in Revit, save it. Unlocker (http://ccollomb.free.fr/unlocker/) is another good tool to unlock files....
Download Problems
Wed, Jan 11, 2012 at 1:10:39 PM
Problems with RevitCity
Sun, Jun 5, 2005 at 11:28:31 PM
BE AWARE .... REVIT problems with mirroring
Tue, May 22, 2007 at 12:43:54 PM
Rendering with Imported Items from RevitCity ProblemS!
Fri, Nov 2, 2007 at 12:30:22 PM
Revit Families
Fri, May 24, 2013 at 4:23:33 PM
12
Page generation time: 3.8599
