Forums >> Revit Building >> Technical Support >> Light Troffer
Mon, Feb 15, 2010 at 5:29:44 PM | Light Troffer
smjda888
Hello everyone! Fairly new to using Revit 2010 and just inserted a Revit supplied light troffer (2009) into a compound ACT ceiling. The light appears to be functioning when rendering but it also appears that the ceiling texture fills in the fixture (see attachment). Any ideas on a fix? thanks in advance!
Mon, Feb 15, 2010 at 7:05:32 PM | Light Troffer
The lights in 2010 don't automatically cut the ceiling.  They did in 2009.  You need to edit your fixture and add an opening cut.
...oops _ I see you say that was a 2009 fixture... You should still check it to see if it cuts the ceiling.  It looks like it doesn't.
Edited on: Mon, Feb 15, 2010 at 7:07:29 PM
Mon, Feb 15, 2010 at 7:12:28 PM | Light Troffer
smjda888
thanks, WWHub, I will give that a shot!
Tue, Feb 16, 2010 at 5:32:44 AM | Light Troffer
4 Stars: 205 Votes
Try this: Pick in the light, pick in "edit family" then pick "load into Project" and check...
Tue, Feb 16, 2010 at 12:11:28 PM | Light Troffer
smjda888
Thanks, Typhoon and WWHub...I got into the Troffer family and it did not appear to have an opening...added one and reloaded in the project...Since I didn't get very far with it, I wiped out the original ceiling and started from scratch again. I tried first w/ a basic ceiling but that didn't seem to work (rendered completely dark w/ interior artificial only) and then went back to original compound ceiling and it now appears to work fine! It renders a bit bright so I'll fool around w/ the dimming or other light characteristics...
Thanks for your help!
light troffer
Mon, Nov 17, 2008 at 1:40:47 PM
T-BAR WITH TROFFER LIGHT
Mon, Mar 24, 2008 at 12:22:52 PM
Surface Mount Troffer Light
Tue, Jun 3, 2014 at 7:19:52 AM
light fixture graphics
Mon, May 14, 2012 at 11:25:01 AM
please help with custom family...
Thu, Sep 1, 2011 at 2:13:11 PM
Page generation time: 0.0776
