19 Users Online (17 Members):
Forums >> Revit Building >> Technical Support >> NEW WINDOW FAMILY
I'm trying to make a new window family. It is a policarbonate' plane. I've done the sash, and modelled the window pane.
The question is: when i change size, i want not the window pane to be stretched, but to be repeated, as it is a 500 mm standard size. Any suggestion??
Is a currogated pane? Have you modelled the corrugations? Or do you just wish to show 500mm standard size panes... In the latter case you would have to setup an array. Very similar to my glass block window in the family explorer...
You could use this as a starting point. You could almost just change the size of the glass blocks to the size and thickness of the window pane and it should still work.
window frame family + nested window frame fill |
Wed, Apr 12, 2006 at 7:31:30 AM
Imported family not flexing in window family |
Thu, Jan 31, 2013 at 7:21:53 AM
Window Legends-showing nested components |
Thu, Mar 20, 2008 at 4:20:36 PM
having trouble with window rfa |
Mon, Sep 8, 2008 at 10:37:11 AM
basic window family tutorial(step by step) |
Mon, Sep 6, 2010 at 7:26:53 PM
