Forums >> Revit Building >> Technical Support >> labeling dimensions
Mon, Feb 15, 2010 at 11:21:33 AM | labeling dimensions
AEckerson
AEckerson Avatar
3.5 Stars: 5 Votes
I've experienced the following behavior many times while constructing families:
There seems to be some kind of non-controllable hierarchy of what should move relative to what.  Let's say I make a series of reference planes and add labeled dimensions to them.  Sometimes, labeling the final space generates an error and the Revit seems to want to treat the unlabeled item as pinned and force the other, previously labeled items to move - thus breaking their constraints.
This is hard to describe, so I've included a pair of screen shots to illustrate.
(I've experienced this on every version of the program, but today's glitch was on 2009.)
Mon, Feb 15, 2010 at 11:42:42 AM | labeling dimensions
4 Stars: 205 Votes
AEck is that "Right" ref. plane a "Defines Origin or a Center/left/right/ strong ref plane"? and the others?
Edited on: Mon, Feb 15, 2010 at 11:47:17 AM
Mon, Feb 15, 2010 at 11:57:51 AM | labeling dimensions
AEckerson
AEckerson Avatar
3.5 Stars: 5 Votes
The right reference plane is a "weak reference" as are the others that I created.  The left reference plane is the default "Center Left/Right" that comes with the Generic Model.  (This is a plan view.)
Just to make sure that none of my geometry was not causing the confusion, I created another file with no geometry, just reference planes.  If you attempt to label the 3rd non-labeled dimension, the Revit gets mad.  (See attached.
Mon, Feb 15, 2010 at 12:07:18 PM | labeling dimensions
4 Stars: 205 Votes
Try one thing: Label first the dimension in the right Ref. plane with "A" parameter then label the left with the same parameter...
Mon, Feb 15, 2010 at 12:59:10 PM | labeling dimensions
AEckerson
AEckerson Avatar
3.5 Stars: 5 Votes
Changing the sequence of labeling the dimensions worked.
I will experiment with this technique and hope it works in other instances.
Thanks.
Labeling Dimensions
Mon, Apr 24, 2006 at 1:49:50 PM
Labeling this dimension would overconstrain the sketch. ??
Sun, May 3, 2009 at 11:14:09 PM
Wall Type Tag Labeling Convention
Thu, Sep 25, 2008 at 9:24:51 AM
Family Help Please! 'Labeling this dimension would overconstrain the sketch.'
Wed, Jun 10, 2015 at 9:18:40 AM
EQ Display in dimensions Revit 2009
Tue, Mar 23, 2010 at 3:28:36 PM
Page generation time: 2.5047
