Forums >> Revit Building >> Technical Support >> Grouping Walls and attaching them to Floors
Mon, Feb 15, 2010 at 10:20:58 AM | Grouping Walls and attaching them to Floors
asharum
Hey everyone. This is my first time posting on here, so I'm sorry if this question is in the wrong area.
 But my question is:
 The firm I work for designs mostly hotels and we have rooms that are usually cookie cutter types, in other words they look exactly the same and have the same layout. However, we have at least 4 floors and some floor to floor heights are different. I've created my basic partition walls and such for the guestrooms to the correct level heights, but when I paste align them up Revit automatically gives the walls an offset. I assume it keeps doing this because of the different floor to floor heights. I hope this doesn't mean that I have to create a diffrent wall type for every floor? If so that would be very time consuming and right now it is becoming a problem because after I paste the walls up to the next floor I have to go into each wall and take out the "Top Offset" height. So is there a way to make it so I don't have to do this every single time I copy walls up???? Also is it a bad idea to group walls with my room types??
I appreciate all your help, if you need photos I can try some. Thank you in advance.
Mon, Feb 15, 2010 at 10:35:17 AM | Grouping Walls and attaching them to Floors
asharum
Forgot to add this but I'm using Revit Architecture 2010
Mon, Feb 15, 2010 at 4:10:51 PM | Grouping Walls and attaching them to Floors
Kardiff
5 Stars: 3 Votes
From the sounds of it you should make a group for each 'cookie cutout' type.
array them acccordingly on each floor (at this point they are in the right place but the walls won't match up)
ungroup them all, highlight all the walls on that floor (using filter tool or isolate category) and set their base and top, rinse and repeat.
Should be a quick and painless way of doing what you want to achieve
Hope that helps
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Grouping Floors
Mon, Aug 22, 2005 at 3:47:49 PM
Attaching stairs to floors
Wed, May 24, 2006 at 11:29:47 PM
Dead horse still kicking - walls and floors strategy
Tue, Oct 2, 2007 at 1:36:25 PM
Attaching Rails to walls
Thu, Aug 13, 2009 at 12:59:42 PM
join all walls with floors toguether ?? easy way?
Tue, Oct 17, 2017 at 2:50:57 PM
Page generation time: 0.3329
