Forums >> Revit Building >> Technical Support >> Needing to create a flowing wall panel system.
Sat, Feb 13, 2010 at 1:01:16 PM | Needing to create a flowing wall panel system.
SirLyons
SirLyons Avatar
I am working on a project that requires the use of a panel system.  I have a few questions that I can't figure out.
I have created a the wall form I was looking to acheive and I attempted to add a curtain panel system to it but it wasn't following the flow of the wall I was creating.
Here are the questions.
Is there a way to create the panels without have to make them individually?
Is there a way to create a custom panel to use in the curtain wall tool?
     I would like the panels to be perferated.
In the curtain system how do you add materials to the panels?
Lastly, am I even going about this the right way, using the curtian wall tool?
If there are any tutorials or anything that could help it would greatly be appreciate.
Fay Jones School of Architecture | University of Arkansas | Design Build | 4th Year
Sat, Feb 13, 2010 at 2:28:18 PM | Needing to create a flowing wall panel system.
Kardiff
5 Stars: 3 Votes
Right I can answer a few of these questions but not all.
1.  change the panel in the modify type dropdown from 'glazed' to 'solid' (or apply it in element properties).  If you then select the panel and check it's element properites you can then change it's material.
2.  when you change material if you use a pre-set metal you can add perferations in it's render appearence setting
3. you can change them all by then editing your curtain wall before you draw it to the panels you've created or use 'isolate category' / 'select all instances' and change it like that
Im not sure what you mean by not following the flow of your wall could you attach an image ?(from a guess you could either use 'change profile' or set the grid pattern to a smaller amount to help fit a complex path)hope this helps
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Curtain Wall System with Wavy Glass Panel
Sun, Mar 26, 2017 at 1:02:18 PM
Wall Panel System
Tue, Mar 24, 2009 at 10:31:06 AM
Curtain system panel problem
Tue, Jul 10, 2007 at 10:08:07 AM
missing empty curtain wall system panel
Thu, Aug 4, 2016 at 7:17:33 AM
Creating curtain wall system on an angled wall
Fri, Dec 16, 2011 at 4:01:22 AM
Page generation time: 2.2047
