Forums >> Revit Building >> Technical Support >> Revit 2010 Extruding Multiple Surfaces all at once?
Fri, Feb 12, 2010 at 10:46:51 PM | Revit 2010 Extruding Multiple Surfaces all at once?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
Is it possible to extrude multiple surfaces all at once in one family? I am not happy with this new 2010 modeling system at all!
Sat, Feb 13, 2010 at 6:33:19 AM | Revit 2010 Extruding Multiple Surfaces all at once?
4 Stars: 205 Votes
Like what? show me an example! here you have several extrusions made at once in one family...
Edited on: Sat, Feb 13, 2010 at 8:37:27 AM
Sat, Feb 13, 2010 at 12:16:35 PM | Revit 2010 Extruding Multiple Surfaces all at once?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
I trying to extrude them all at the same time, instead of extruding them 1 at a time which is time consuming. I have about 30 extrusion objects, and doing them one at a time, is time consuming. In 2009 I can extrude all in once, with this new modeling thing... I dont have a clue lol... Thanks
Sat, Feb 13, 2010 at 12:24:08 PM | Revit 2010 Extruding Multiple Surfaces all at once?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
here is an image i am working with... see how each individual one has its own pull... i want to pull them all at once
Sat, Feb 13, 2010 at 2:35:25 PM | Revit 2010 Extruding Multiple Surfaces all at once?
Kardiff
5 Stars: 3 Votes
if you made your extrustion on the reference level just highlight them all and set the 'start' and 'end' elevation to the correct distance.If you need to edit width i suggest draw one right and then copy/array all 30
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Sat, Feb 13, 2010 at 8:25:19 PM | Revit 2010 Extruding Multiple Surfaces all at once?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
not totally sure whats going on...
 I am in 'Massing & Site'
 Click on 'In-Place Mass'
 I name it.
 I draw all the profiles with the 'Make surface from closed loops'
 I select all, PR, and there is no option for Start or End.
Sun, Feb 14, 2010 at 3:03:26 AM | Revit 2010 Extruding Multiple Surfaces all at once?
Kardiff
5 Stars: 3 Votes
on the ribbon while you draw it where will be an element properties button
the first two options should be extrusion start & extrusion end
also while you draw it in the upper left just below the ribbon it should have a 'depth' figure
use those while you draw your in-place mass
Sun, Feb 14, 2010 at 5:59:22 AM | Revit 2010 Extruding Multiple Surfaces all at once?
4 Stars: 205 Votes
Pamoroso, you are doing that with the "Massing" tool, you have also the "In-Place" tool in Home>Component>Model in-place.. that's what Kardiff is talking about... only use the Massing tool if you want to create wall, roof, floor and curtain system by face, if this is not the case (and i believe so) use the "In-Place"...
By the way, is those objects columns???
Sun, Feb 14, 2010 at 10:31:48 AM | Revit 2010 Extruding Multiple Surfaces all at once?
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
oh thank you so much typhoon! i thought they got rid of this feature all together! this is beautiful! thank you so much!
Mon, Feb 15, 2010 at 2:58:03 AM | Revit 2010 Extruding Multiple Surfaces all at once?
4 Stars: 205 Votes
No man, they don't get rid of that, look, this is a site where you can find the new commands in 2010: http://www.nichitecture.com/downloads/Where%20is%20my%20command%20in%20Revit%20Architecture%202010.html
Cheers
Mon, Feb 15, 2010 at 10:51:00 AM | Revit 2010 Extruding Multiple Surfaces all at once?
#11
pamoroso
pamoroso Avatar
4 Stars: 4 Votes
thanks for that! Smile
Mon, Feb 15, 2010 at 10:59:05 AM | Revit 2010 Extruding Multiple Surfaces all at once?
#12
4 Stars: 205 Votes
You Welcome...
Copy Multiple (RA 2010) default?
Fri, Oct 24, 2014 at 9:20:03 AM
Toposurface Help (Merging Surfaces) Road and Curbs
Tue, Jul 29, 2014 at 8:10:48 AM
Angular surfaces
Fri, Oct 16, 2009 at 2:23:30 PM
import dwg surfaces into Revit
Fri, Mar 6, 2015 at 1:56:09 PM
artlantis renderer 2.1 + revit 2010
Wed, Jun 17, 2009 at 10:22:58 AM
11
Page generation time: 5.7036
