Forums >> Revit Building >> Technical Support >> Drawing List
Mon, Sep 12, 2005 at 12:11:52 PM | Drawing List
swarch
How can the drawing list be arranged so as not to show up in alphabetical order of the Sheet Numbers. Such as placing the E series drawings at the bottom of the list with S series in between the A & Es?
Mon, Sep 12, 2005 at 6:11:28 PM | RE: Drawing List
Mr Spot
Mr Spot Avatar
4.5 Stars: 93 Votes
Goto Settings--Browser Organisation and create a new sorting based on what your require...
Thu, Feb 8, 2007 at 12:57:50 PM | Drawing List
MattEarl
5 Stars: 2 Votes
I know this is an old thread but I figured out how to create this type of Drawing List.
I created a Parameter to the Drawing List, And called it "Drawing Order"
Now you can sort the Sheets in ascending order using this Parameter, just type the number you would like to have each sheet ordered in the drawing list.  So now you can have pages anywhere you like!!! Don't forget to go to the Drawing list formatting an edit the "Drawing Order" parameter as "Hidden"
Happy Drawing!
MH
Revit Drawing List
Tue, Mar 15, 2011 at 5:20:07 PM
Drawing List's
Wed, May 26, 2010 at 11:49:42 AM
Adding a check box list to a drawing list
Thu, Apr 21, 2016 at 5:17:56 PM
Column sizes in the Drawing List
Mon, Jul 13, 2009 at 2:24:16 PM
Drawing list schedule
Mon, Mar 27, 2006 at 7:23:47 PM
Page generation time: 2.7643
