Forums >> General Discussion >> Revit ROI >> Prefix in dimension style
Fri, Feb 12, 2010 at 5:05:13 AM | Prefix in dimension style
celth
Hi - I've goto a question. I'm sorry if this came up somewhere before but i could not find anything.
Basically what i need is to create a dimension style with "±" embedded prefix.
I know I can add this while editing the dimension element properties,
but it's a problem while there can be many dimension lines of this type.
Fri, Feb 12, 2010 at 5:59:51 AM | Prefix in dimension style
Kardiff
5 Stars: 3 Votes
After making the dimension you can click on it to open up the dimension text box.
you can add prefix and suffix's there (as well as any text you want above or below the dimension)
- Just trying to help out while I wait in the office for my renders to complete
www.danrossiter.co.uk
Fri, Feb 12, 2010 at 6:04:31 AM | Prefix in dimension style
celth
As I've said - I know i can do it that way, but is there a way to create a dimension style with the embedded prefix?
 edit:
Or is there a way to add a prefix in many dimensions at one time?
Edited on: Fri, Feb 12, 2010 at 6:14:56 AM
Fri, Feb 12, 2010 at 6:12:42 AM | Prefix in dimension style
NOne that I know....
Fri, Feb 12, 2010 at 6:16:08 AM | Prefix in dimension style
Kardiff
5 Stars: 3 Votes
Sorry I misread
from having a little play I don't think so.  As you can't set it in the element type properties only in the dimension text type
Fri, Feb 12, 2010 at 6:29:02 AM | Prefix in dimension style
celth
Thats too bad becouse its irritating to have to click every single one dimension to change this,
especialy if a drawing contains many of this type.
Thu, Mar 11, 2010 at 12:13:18 PM | Prefix in dimension style
pepsiqueen
pepsiqueen Avatar
I agree, there should be a way to set a dimension type with a prefix. i guess i have to spend a bunch of time adding +/- to a bunch of dimensions...
I'd rather be riding at whistler. or highland. thats good too.
Thu, Dec 16, 2010 at 9:15:11 AM | Prefix in dimension style
jamiew
I agree.  We also use MAX. or MIN. as a suffix on a lot of our dimensions.
Autodesk Revit MEP 2015
CREATING DIMENSION STYLE w-embedded text?
Thu, Jul 24, 2008 at 1:42:38 PM
Stacked Dimension Text (Prefix/Suffix)
Fri, Jan 27, 2006 at 6:21:26 AM
What controls Dimension style of inserted Labels?
Tue, Aug 6, 2013 at 12:37:46 PM
Dimension style
Wed, Oct 5, 2005 at 6:04:18 PM
Inserting text under dimension in string dimension
Thu, Apr 2, 2009 at 9:47:51 AM
Page generation time: 0.5036
